BUDS port
qasamm
I own BUDS, have used it on a few Spyders and am confident in hooking it up. My 2915 F3s puzzles me. I can't get a connection. The plug is under the frunk insert and has far fewer wires running into it.
Any ideas why I can connect to every other Spyder but mine?
Do not try and use the one under the trunk, the correct one is under the top plastic cover right hand side beside the radiator fill cap, have you updated the BUDS software to the F3 if not it will not read it.
Updated my BUDS last year.
Some Spyders have two plugs. They are identical in shape. One has 3 wires. The other has 6 wires. Use the one with 6 wires. There usually is a white tag around those wires also. The plug may be tucked into a blank socket in the tuperware for storage.
Read the above feed I have already given the correct info where it is.:banghead::banghead:
BUDS plug photos
attachment.php
attachment.php
Now I hope this is will help all that want to know where to find the correct BUDS plug.:yes::yes:
Bruce:
I did read your post. I merely was adding a little extra information that I thought the OP and others may find helpful. Please read my post with the bold, underlined words. You may understand where I was going with it.
And somehow you hook a terminal to this?
BUDS is more accurately the software program that interfaces with your Spyder and implements diagnostic trouble code reads and changes/modifications to the system that runs your Spyder.
The CAN-BUS system your Spyder uses is a proprietary version of the industry standard.
It has quite a few differences which is why you can't just hang a normal DTC (Diagnostic Trouble Code) reader on to the connector and get anything useful.
Thank you- didn't realize some have 2 plugs so I never considered looking for the right one!
