teninospyder
My ACS on a 2014RTL SE6 does not seem to be functioning properly, and it was suggested on the forum that the BUDS settings may have changed or be incorrect now for some reason (16,000 miles total), because the system does hold air.....but goes on and off much too often when on the road or at a stop sign, etc. I tested .... per some good forum input..... and the movement with one rider on, is only 1" total, whereas I'm told it should be around 2" total per spec. This problem was first noticed by me and my wife because the pump was seeming to come on much to often while getting ready to ride, or riding or sitting at a stop sign etc.
Now the question. My dealer says that checking the BUDS settings is NOT covered under the extending warranty (even if they are the problem), and in fact even if there are BUDS updates from BRP for any reason, the installation of those is not routine and aren't covered either. I.E., asking for any BUDS checks will cost you (labor fee), if no PART problem is found !!
Is this the case everywhere or just my new dealer ? BRP......any response that will clarify ??
