Break Light Problems
lanerider
I have a new 2014 Spyder RTS and my husband tells me that while we are riding, he has noticed that my break light is staying on. If I try to pull up on the break the light will not go off but if I tap the break it will turn off. Any suggestions what I should do? I have owned it for 45 days and have 1500 miles on it.
Could be some road crud gumming up things on the underside of the Spyder. Suggest you run it to the dealer as it should be repaired under warranty.
:agree: Try cleaning it first, and then let the dealer take a run at it...
Good Luck; please let us know what does the trick! :thumbup:
Depends..!
Ryding with your foot resting on the brake will cause the light to go on but if you do it long enough you will get brake failure warnings. The brake switch is likely the problem cleaning and or adjusting it will solve it (seems to be sticking). If not your thing then as mentioned above run by your dealer for a check...:thumbup:
