Changed the brakes today
My new EBC pads and rotors came in yesterday (Thanks, Ron!), so this morning I installed them. It took me longer than I anticipated because of the clips on the backs of the pads, and just because this was my first brake job on the Spyder.
The torque on the lug nuts was uneven, with one so tight that I lifted the left tire off the ground. Definitely overtorqued. Others were more reasonable.
After I jacked it up and put safety stands in place, and got the tires off, the brake assembly was very accessible. 2 caliper bolts out, and the caliper and rotor came right off. I popped the pads out, and used a 4" C-clamp to compress the pistons into the caliper.
Then the fun began. I used a utility knife to separate the backplate from each of the old pads. There was a contact adhesive holding them together that had to be cut through, so I slid the blade into the joint and opened the gap enough to get a small screwdriver in to pry it open.
The clips are from Satan's workshop! :cus: I tried every pair of pliers I have, and just couldn't squeeze the clip together and lift the clip out of the hooks that hold them. Ultimately, a pair of snap-ring pliers saved the day. I was able to seat the pins of the pliers into the clip ends, and it gave me enough daylight that I could slip a small 1/8" flat screwdriver tip in and lever the clip out. The first clip took me an hour and a half to figure out; the rest of them went really fast because I had a technique that worked well. Same learning curve on installing the clips onto the new pads- went through all the pliers, and the snap-ring pliers were the only pliers that worked. Squeeze the clip ends together, put the clip on the pad and push down with thumb, and release.
The gap between the new pads was a little tight on the left side and I had to use a small dead-blow mallet to get the caliper on to the rotor. I didn't clobber the thing; a little tappity-tap did the trick.
18 lbf/ft on the caliper bolts, 77 lbf/ft torque on the lug nuts, checked brake fluid levels, and now it is ready to test. :spyder:I'll have to wait until tomorrow, though. This afternoon was taken with other stuff.
The old OEM rotor on the right has about .005" of runout. Max warp allowed is .004", so this rotor was definitely out-of-spec.
