Brake squeak at low speed - any quick fixes?
OldStuff74
Installed new OEM pads 2000 miles ago. The front brakes are starting to squeek at low speed. Rotors a in spec and no rough surfaces. Any quick fix for this? 2019 RT Limited with 35000 km.
Giving them a GOOD cleaning may help; there is also a product you can get at most auto supply stores that you put a" light" film on the back side of your pads so that you don't have metal to metal contact!
By all means, applying anti-squeal compounds to the back of your pads is definitely not a "quick fix". I had a momentary slow speed squeal in my brakes when my spyder was relatively new. The dealer service department lead mechanic said next time I was at the high pressure carwash, hit the rotors and pads with a couple of quick shots and clean out the dust. Much to my surprise, that worked.
Were the brake pads flat or were there grooves cut into the brake pad? If there is not a groove - they will squeal.
