Aracnid
2016 Limited RT. Purchased new Aug 2017. About 3000 miles ago, I started having problem setting Cruise Control (threw a code). Took into shop - Service Mgr. said code indicated a faulty switch. Part was replaced and I was sent on my way. After a few miles I was unable to set Cruise Control again. Took RT back to dealership (they had it a full week) switch replaced and system bled again. Picked it up and within 20 miles same problem. Through course of time, I found that I needed to lift pedal with shoe then it would set. This happens nearly every time I apply the brake. Only thing Svc Mgr says is that it shouldn't be doing that. "it was working when I test drove it" and will check with BRP again.
Anyone have a solution - apparently BRP/dealership doesn't. Thanks!!!
