Brake pedal extension
I have the brake pedal extension (tricled) as mentioned above. I also have seal floorboards.
I had some concerns at first that it would bottom out on the floorboard--but it has not. Seal gives you a extra nut and some longer screws that raise the pedal height a bit.
I also had some concerrns that the extra weight of the pedal would make the spyder think I was riding the brake pedal and cause it to go into limp mode. After about 500 miles with the new pedal--I have experienced no problems with either of the above.
I like the pedal extender. 4 stars at least. :thumbup::thumbup::thumbup::thumbup:
REDAL EXTENSION
I made mine SMALLER ...is something wrong with me......don't answer that Firefly...or you either Coz.....or Randy...or Bob or Bob OH What the He** or ANYBODY...:gaah: :agree: :roflblack::roflblack::roflblack::roflblack::roflblack:.....Mike.....:thumbup:
You've just GOT to be different; right Mike?? :thumbup: :roflblack:
Did you cut it down because you were hanging your foot on the side of it when stabbing at it? :yikes:
BRAKE PEDAL
Exactly BoB, you nailed it first time out of the box. Move over Scotty ..Bobbbbbbbbbbb's coming thru.:roflblack::roflblack::roflblack::roflblack:. Yea I never had any problem finding it...Just finding it when I didn't want tofind it ...if you know I mean.....Help me BoB......Mike....:thumbup:
I paid $2.49 for a piece of metal bar at home depot, cut it to size, drilled 2 holes to match the factory holes on pedal and use that as extension. $2.49 was the total cost since I had the tools to cut(jig saw) and drill.
I am far from being handy with tools so its not that hard.
This idea was from a 65 old lady in San Diego back in late 08.
I felt that brake pedal did not extend out far enough the first time I sat on the spyder.
The nicest part ofyour solution is that you can easily "tinker" with it to make the size and shape just right for you! :thumbup:
For a finished look; have you considered dipping it in that "liquid rubber/vinyl" stuff that they use to coat tool handles? That even comes in colors...
I've only extended 1 hole width and most of extension is covered by peg. Plus it's black and hardly noticeable.
But I will using plasti-dip on other parts to black them out.
PEDAL ADJUSTMENTS
I just love to see people thinking out of the box.......you guy's ROCK.....Mike:clap::clap::2thumbs::2thumbs::2thumbs::thumbup::thumbup::thumbup:
