Brake failute
adiah51
Brake failure light came on my 2010 Can Am Spyder RT. Fluid is good, no leaks, fuses good. Rear brake pads low. Ordered new ones, but was wondering if anyone else has had this trigger the brake failure display before or is there something else going on??
Check the parking brake
We had one fail on Wednesday. Cable slips off the front pulley. Check that, too!
This happens quite often due to various things, low brake fluid being a main one. However, when your rear pads get thin you will definitely get the failure light. Sometimes the pads are not thin but the bar they slide on gets a build up and the pad doesn't return properly. If you're doing your own work, make sure that bar is thoroughly cleaned with a tiny bit of moly lube on it when reinstalled. If you ordered OEM pads they come with new bars.
