Brake Failure
daviszoo1
Any help will be appreciated; 2015 RT Limited. less than 600 miles. Have had the dreaded orange screen Brake Failure (4 separate times) and also Low Brake Fluid (1 time along with the Brake Failure). Currently at the dealership. Brake Master cylinder is full to the top of the caps. Dealership has not been able to duplicate the code in the shop however the codes are in the Bud report. Currently the mechanic is awaiting BRP tech for help. Anyone had the same issue? Thanks for any help...9 days in shop so far..
Not saying you are, but are you sure you are not riding the break peddle at all? Even the slightest touch?
Bob
Same thing happened to me on my first ride when I bought it. I found the side of my foot was touching the brake pedal. I pulled over and stopped. Restarted the bike and no trouble since. I don't think I was pressing it, only touching it with the side of my foot.
Thanks everyone-I will pass this on to the mechanic. This is my better halves bike. It is her second RTL. Previous was a 2013 rt limited. Will mention the touching/pressing pedal at all...(may not have happened on the '13 due to the hot foot area..lol) appreciate your input..
I would also check to see if the brake light stays on from time to time, this happened to me on my 2015 RTL
Bad Brake switch.
Cruzr Joe
