NancysToy
Motorbike Professor
Well done, Ron! I was trying to figure out how to explain this without pictures.
BTW, if you have to add much brake fluid, be sure to inspect your brake pads. They may be worn to the point that they need to be replaced. On a similar note, if you top off the brake fluid, you may have to siphon or bleed some out when you replace the pads later. Keep a close watch on the master cylinder when you push the piston back into the caliper. You don't want to spill brake fluid on anything. It is very damaging to painted surfaces.
