While riding my 2008 GS at Maggie Valley the “brake failure” warning scrolled across my dash. I checked for the code and it showed O C 1282. I added a slight amount of Dot 4.
I park it in my garage and there is no sign of leakage. I cannot get the brake failure to clear.
I tried both of the following several times:
Turn key on and wait for the screen to finish booting up. Press the brake pedal hard enough to activate the low pressure switch. If you have good hearing it will be the 2nd click. While holding the brake pedal down. Turn the ignition key off and wait 30 seconds. Release the brake pedal.
Turn on the key and wait until system is fully booted up.
Press the brake peddle for the 2 clicks.
While holding the brake peddle turn the key off but this time before it fully shuts down, turn the key back on.
Is there any other way to clear it besides taking it to a dealer?
