I finally corrected the "BRAKE FAILURE" message that's been scrolling across the display on my '08 GS for months. There was never anything wrong with the brakes - the message just appeared for no apparent reason. The error code was C1282 - Low Brake Pressure. Turns out the problem was a flaky connection in the brake pressure switch connector. Unplugged it, plugged it back in and everything was happy. Glad I didn't have to bleed brakes...
BTW - a C1282 can be reset by the operator - it doesn't require BUDS. Here's the procedure:
LPS fault c1282 reset
1 turn Ignition switch off
2 wait 30 seconds
3 turn Ignition switch on
4 firmly press brake pedal untill you hear a click from the LPS switch
Note , the 1st click will come from the brake light switch. Continue to strongly press to hear a 2nd click. This one wiil come from the low pressure switch
5 Turn Ignition switch off
2 wait 30 seconds
