Bob T.
Bob T.
I had the warning light coming on all the time for parking brake failure. I asked the dealer about it and was told there is a little lever underneath the round pully that might have got bent. If he could'nt straighten it out He would put a new switch at $35.00 plus labor. I took the right panel off seen the broken lever so I cut the wires on the switch problem solved. I hardly ever use the park brake, I leave it in 1st. when I stop. The brake still works I don't have the red blinking light. Just in case somebody else has this problem
When you burn the brake pads and rotor, Then you will hook it back up. $ :yikes:
I know a couple of guys who have totally removed the parking brake off of their SM machines too.
I rarely use mine either.
Interesting..!!
did the lever break from lack of use..??:roflblack: I don't always use it but it does come in handy in many cases. If the park brake was on a two wheeler I would chuck it in a heatbeat. But yo each his own. It is good to know in case your out and the trip home is long to stop the flashing light...:thumbup:
