From my experience it mostly drips down on the right side of the Spyder, from the airbox (just behind the coolant tank), and drips onto the Radiator on the right side. It can then drip in front of the fan, which blows it rearwards slightly making it land on the black panel that the air from the radiator exists. You may get an oil burnt smell from where it cooks on the top of the radiator. It may run down the side of the fan on then onto the ground or your garage floor - take a peek underneath when you're parked for a while.
I am running stock and recently cleaned my airbox for the second time. Taking the panels off and cleaning the airbox is not so bad and it gives me a chance to check out other things under the panels while I'm at it.
There are a number of solutions. Mostly common is installing a catch can system that catches all of the blow-by oil in a small container so you can easily see it and depose of it when it gets near full.
The other option that I considered is installing a small section of sponge in the vent tube - this is supposed to keep the oil out of the airbox and I think keeps it in the engine and oil tank, really.
Are you seeing oil on your engine? Where? If you think you are seeing blow-by oil, it is easy to verify that's what it is:
1) Open the trunk on your Spyder
2) Remove the service panel - so you can see the coolant tank
3) Get a flash light and shine it passed the coolant tank at the airbox
4) You'll need a good bit of light - and look at the seam in the airbox where the top meets and seals to the bottom half - right in the middle of the airbox.
5) If you see oil there that looks like it seeped from the seam, it is likely just blow-by oil. You may want/need to clean your airbox, very soon.
6) Since you're in there, use the flashlight to backlight the coolant tank and check your coolant levels
If you are seeing oil in any rate, outside of the engine, the source needs to be found, just to be sure it is not a serious issue. From what I understand blow-by is a normal characteristic of these engines and other engines that are so high strung. Blow-by oil is not a serious issue, it is just a mess, but does need to be cleaned up once it starts to seep outside of the airbox.
I am sure others will post, also.
Hope that helps for now and please keep us updated on your findings.
Cheers from Newfoundland.
