BEST warranty again
Tx web rider
why is it BRP does not honor their warranty when you have no modifications to the motor and stock air box and filter and stock silencer use their oil and filters on their recommended skedual
my 09 spyder developed a case of puking oil a couple weeks ago through the crank case vent tube had almost a qt inside the box
no it was not over filled !
after it went to the dealer they did some basic leak detecting and after discussing with the mechanic he dug deeper to figure where the oil was coming from
after a compression check the forward cylinder is at 95 psi and rear is at 205 both should be over 200
they tore intoi the cylinder to discover the rings are fused to the piston and the sleeve is scarred badly
now BRP is saying this is not a covered item
how can using their products on their time frame with a totally stock motor cause a fault like this that they are going to say is my FAULT and not warranty
what the hell good is the BEST warranty then
We will be watching the situation and are interested in how your problem will be solved.
Your question about the warranty is a good one. :bbq::bbq:
Even if you have mods, don't they have to definitively demonstrate that the mod caused the issue?
Are pistons and rings concidered a wear item ????? Read the fine print of your warranty to be sure. My warranty info spells out everything that is covered and not covered. I'm not sure what BEST does.
Sorry your engine blew. :(
warranty
ok i dont have a copy to read so ill talk your word on that
but who is to say there is not a malfunctioning part causing this issue
this bike was running 70 down the highway then started belching oil and i drove it home 40 miles due to no other avenue to get it there (stopped 2 times to add oil )
granted a wear item but an instant failure like what im seeing i don't buy its the rings alone
BEST
ENGINE:​
• Pistons• Cylinder heads• Cylinders• Muffler​
• Crankshaft
So much depends on how the dealer presented it to BRP, as well as what his (the users) max RPM numbers look like. Could be that a ring broke. Could be that something else let go first. Sounds like the owner needs to get together with the dealer and find out how they presented it to BRP. Then if he's still not happy he should ask BRP why they came to the conclusion that the repair will be on his dime.
Just a simple mans opinion.;)
BEST warranty
interesting i looked on line under best warranty and found this
http://www.spyder.brp.com/Files/en-US/Pdf/BEST_Protection.pdf
at the bottom of the whats listed there
Parts, parts and more parts
Ride as much as you like without worrying about
ENGINE:
• Pistons
• Cylinder heads
• Cylinders
• Muffler
• Crankshaft
TRANSMISSION/
PROPULSION:
• Drive shaft
• Jet pump
• Riding plate
• Venturi
• Transmission
BRAKES:
• Callipers
• Master cylinder
• ABS
• Speed sensors
IGNITION & STARTER:
• Rewind starter
• Starter relay
• Starter drive
• Stator
• Magneto
• Electric starter
SUSPENSION &
DRIVE SYSTEM:
• Differential
• Drive shaft
• CV joints
• Drive axle
• Countershaft
• Chaincase
ELECTRICAL:
• Ignition switch
• Voltage regulator
• Electronic modules
• Speedometer/
Tachometer
• Vehicle stability
system
FUEL SYSTEM:
• Fuel tank
• Fuel injector
• Fuel pump
• Carburetor
• Throttle body
the only thing i see thats not covered is in this little statement
Note: accessories, normal wear and maintenance items such as tires,
batteries, bulbs, filters and lubricants are not covered
in this document it sure looks like the cylinder ,piston and heads are covered
i might be picking threads apart but its my disabled vet ass on disability income that's on the line to cover what they say is not covered
BEST - fine print
FWIW - If you know where your BEST contract is? Take the time to read all the fine print. You may need a magnifying glass and the assitance of a New York attorney but it's worth a SLOW and comprehensive read.
BEST warranty
since i purchased my spyder second hand and the previous owner left the warranty on it and had it transferred into my name i have no contract to read
All BRP has to say is the ring is a normal wear item which took out the piston which took out the cylinder wall and he is up the creek. It looks like BRP left out rings with their engine coverage breakdown.
I understand this posters frustration and these Best warranty problems seem to pop up about 1-2 times a month here.
I also understand where the dealer is coming from not wanting to cover it. My tech told me that BEST warranty does not pay them full price for warranty work. I'm not sure how true that is, but it would explain alot of the reasons the dealers won't push to get thing covered.
Simple
Your dealer should have contracts. Ask him for one.
All he has to do is mark it VOID...SAMPLE ONLY.
Another example of too little information (both sides of the story) to reach a quantifiable conclusion.
BEST warranty
would love to go pop in on a dealer to get a copy wow the closest was 145 miles away its was shut down now my next closest is 175 miles away
BEST Warranty
I bought a 2012 RT-S SE5 :spyder2:( in July) thru a dealer, ( in Vermont ) and got the 4 year warranty,and the"BEST Warranty". I did not see a phone # on the flyer to call if i needed to call,( if i broke down etc. ) So I asked the dealer for the Phone # for the "BEST Warranty" The dealer gave me the phone #....... Deanna777:ohyea:
ENGINE MAINTENANCE
Playing devil's advocate here.....At what Mileage does BRP recommend you to change your RINGS ????....just ask-in...Mike :thumbup:
update on best warranty
i spoke to the mechanic at F & T valley motorsports in Pharr TX a couple days ago and BRP finally made their decision on the destruction of the front jug on my 09 rs
BRP will pay for the parts and labor for the fix of my bike
not sure yet if its a full fix on their dime or not but its a great leap forward
Thank you BRP
mechanic said they should have the parts in next week and start re assembly
i might make spyderfest after all :pray:
Good news..!!
Glad they came through for you. Seems like forever but you'll be back on the road again..:clap::thumbup:
