best master cylinder for hand brake
bhook
What is the best master cylinder to us for a front brake set up with a slave cylinder? I know the one from a Yamaha xs 650 is supposed to work, but it looks out of place. Any body know of any other 22mm bore cylinders?
The Spyder's brake system is made by Hayes Brakes. You might want to contact them for sources on a matching front brake handlebar assembly.
Click here: http://www.hayesbrake.com/
Let us know what you find out. I've been meaning to call them but....
My best intentions to do the same have not yet come about either...LOL
I was hopin I could find the same thing.
I am using a harley master cylinder . Its for dual front setup. Got it off of ebay for $25. I also used a slave cylinder from a 90or 91 toyota T100 pickup. $12.95 from advance auto parts. It all looks good and works great.:2thumbs:
What did you do about the 1" bar size? Did you shim it?
It fit just fine. Didn't have to shim anything with mine. But shimming it would be pretty easy to do if you had to, or file down the halfs alittle would work to, wouldn't it? :dontknow:
Here are my pics.:clap:
