Best aftermarket air filter?
Filter
Which aftermarket air filter is the best? Evoluzione or Green preformance.RAL
I would say that if you own the "green" then that one is the best and for those who have the Evoluzione filter then that one would be the best. I haven't seen any flow data on either. But I'm sure that either one would be a great improvement over stock.IMHOnojoke
Michael:doorag:
They both provide better seal than OEM. Whichever one cost the least delivered to the front door is the best. Evo can be bought on eBay right now with best offer of $60 w/ free shipping.
Having been the one who worked with Green Filter to design the Spyder filter they manufacturer exclusively for the Street Magic Product line, here is what I can tell you about the Green Filter's design.
The Green Filter will have almost 1.5 times the air flow over the stock filter
The Green Filter has better dirt holding capabilities showing almost no reduction in flow even when totally loaded with dirt.
The Green Filter comes with a lifetime warranty backed by Green Filter direct, and they will be there to back it both now and in the future if you should ever have a problem.
The Green Filter has the a complete filter service kit made by Green Filter and availble through any Street Magic Cycle Products dealer at a very reasonable price. Which makes it quick and easy to maintain your Green Filter for top performance with the correct items to do it right the first time.
The Green Filter uses their proprietary filter frame design to eliminate the filter sides from caving in allowing dirty unfiltered air reaching your motor like happens all too often with the stock BRP design.
The Green Filter can be purchased through from any of the over 300 Street Magic Cycle Products dealers.
This is what I can tell you about the Green Filter, as for the others out there??? :dontknow:
MM
