billybovine
Thanks for posting this as I just could not figure out where these numbers were coming from. If you use the Torque tab instead of the Force tab you'll get the correct numbers. I agree that the Force tab would seem to be the right one but for this excersize the Torque tab gives the numbers we are looking for. If you use the Force tab numbers and the smaller Krikit your belt is going to be way too loose.
Torque is the measurement of rotational force. No rotational force in belt tension. The BRP spec is N (newtons, force) not N-M (newton meters, torque).
