DragonSpyder
For those that have not changed your belt tension to the new recommended setting I would highly recommend it.
I heard about the new recommended tension and asked my dealer and was told it was only for new Spyders as part of the pre-delivery setup. A few weeks later I started hearing a slight grinding noise coming from the front sprocket. I did an inspection and all looked OK and convinced myself it was the belt rubbing. About a 100 miles later the seal blew out on the highway. I do have 17K miles and thankfully it's still under warranty. If I had them change the tension it probably would not have blown out until my warranty was up.
I'm fairly certain the blown seal is due to the high belt tension so I recommend everyone get it changed ASAP.
