My ongoing experiment on the vibration:
Put a new rear tire put on two days ago. The tech and I discussed the rear and front sprocket alignment as being a potential problem for not only the squealing, but also the "dreaded belt vibration" (and possibly excessive wear on the rear tire -- but more on that later).
The belt vibration, in particular, appears to only happen for most at higher speeds. High rpm's in lower gears does not appear to produce the same vibration; thus the rpm's are beginning not to be suspect of causing the "belt vibration".
It could be a combination of factors causing the vibration -- to include the alignment of the front and rear sprockets. If the rear sprocket (affected by the alignment of the rear tire) is out of alignment, even if an almost immeasurable amount, means the rear tire is skewed "ever so slightly" sideways. At higher speeds, the tire sliding sideways on the road causes undue friction and could easily cause tire vibration and harmonics at certain higher speeds.
When this happens, the rear sprocket will also vibrate, which then will send the vibration to the "long" belt -- causing it to vibrate.
There is an adjustment procedure when replacing the rear tire rim; however it may not be as accurate as it needs to be.
We worked on mine with some additional measurements, as sort of an experiment, to see if we could align the sprocket to tighter tolerances, in an effort to see if it would eliminate either of the problems.
About a 60 mile test ride provided no squeal, and the vibration only occurred twice for a split-second, and was not as intense as was previously.
Some have also mentioned the engine mounting needing some adjustment also. We believe this also can add to the vibration; however for different reasons than the alignment of the rear tire.
60 miles is not enough of a test yet... so I'll continue to watch it until either problem occurs again or I need servicing. If it does not appear until I need servicing... then we might have something we could recommend for others. Time will tell.
