Belt alignment - bad motor sprocket
Thanks for info - but change rear bearings when I change the tire out last year - pro active - and the the bolt was tight ---
Just giving a heads up if you have this sprocket on your spyder you better change it out now or pay bigger bucks later - because it will fail.
Belt moves off sprocket in reverse
Last year broke belt on freeway changed belt and yes front sprocket was all worn off replaced brought back to dealer for belt alignment all good now! It's been about 7000 miles but when I back up in reverse belt starts to walk off back Sprocket!!?? Why is this happening would it be because of wheelbearings? I now have twenty eight thousand miles with oem bearings on my second tire. What's your thoughts, everyone? When I go forward, it realigns properly. And don't be funny and say don't "use my reverse" lol!
