Beeping while shifting & pop while using signal
HedonismBot
Had the strangest thing happen out of the blue today. My wife and I took our 2012 RT-S SE5 with 1993 miles on it out to the Great River Road in Illinois. We were riding for about 3 hours total when on the way home hit a red light. When we took off and shifted into 2nd (28mph or so) there was a loud beep--even the wife heard it on the back. Every shift up through 5th came with the beep. I'd depress the shifter, a high pitched beep would happen and then the gear would happen normally--nothing strange. I downshift manually for the most part and each time it was the same as shifting up. This happened for the next 50 miles home without fail.
When we got home, I shifted into neutral and again a beep. From neutral, I kept downshifting thinking it was maybe the spring in the trigger needing a lube, but this wasn't the case--no beep. I dropped it into Reverse and beep. Neutral...beep....first beep. When I say beep it sounds very electronic like an error beep in Windows only higher-pitched but about the same duration. At first I thought it was the nanny pitching a fit but no error messages on the display and no limp mode.
Another weird this is that you can now hear a sorta static pop when you first engage the turn signals. It's never made that sound before and started at the same time as the shifting beep. The pop sounds like when you turn on a stereo and the speakers make a little pop or when you plug in your headphones. It doesn't do it when the light blinks only when you first engage the turn signal and I swear it sounds like it is coming from the speakers. The beep I can't tell for sure where it's coming from but it is definitely not the gear trigger.
The turn signal static pop made me thing it was some sort of ground loop type issue. Engaging the signal sends the electrical signal that maybe is loose and touching some part of the body resulting in the noise over the speakers? It seems suspicious the turn signal issue and the gear selector would both develop some sort of audio noise at the same time but the gear trigger won't cause the beep unless a gear actually changes. One other thing, even when the RT-S downshifts on its own, the beep happens. :dontknow:
Any ideas? Seem safe to ride? I plan on taking it in Tuesday but kinda wanted to ride tomorrow with the nice weather
Interesting..!!
sounds like you have an electronic gremlin...:roflblack: Are these noises coming through your sound system.? Or like the park brake alarm.? When you shift you are sending a signal through you gear indicator. Turn signal is also sending a signal to your indicator light. May be a console issue..:dontknow:
I'm 99% percent sure the turn signal noise is coming through the speakers--less sure for when my gears change. I'll have to have my wife listen to the speakers tomorrow during the further testing. I hate electrical gremlins as they seem like the hardest to trace and solve. :sour:
Change the Radio Station, AM to FM , lower and raise the volume, turn the radio off (if you can)(pull the radio fuse). Do you have the CB Option? Just thinking:gaah::banghead::banghead:
Good idea about the radio. Now that I think about it I switched from FM to Aux at that stoplight where it all started. No CB but this gives me something to try tomorrow!
Are you SURE thatyo didn't climb into a telephone company truck by mistake?? :shocked:
(Sorry; I've got nothing on the problem, and those trucks have the loudest beepers...)
Before you start to fix the problem, let your dealer hear it. You might cause it to go away but not really fix it. If it is still under warranty, you want their involvement in correcting the problem and/or for future information.
I went out Sunday and fired it up checked to see what the volume and input were. I switched it from aux which my phone was plugged into for Pandora and the volume was super high (80%). I turned it down to maybe 15% and to FM and everything was fine. No beep and no noise from activating the signal. I'll leave it that my phone which had bugged out while riding was causing some sort of interference. As I get some more time in the saddle this week, we'll see if it returns. Maybe the gremlins went to the neighbor's house to play in her dirt bike. :pray:
