Battery tender
Sccar
I have always used a tender on my bikes and wanted to do the same with the with the F3 but it looks like I will have to keep the frunk open to do that. Has anyone done anything different? Looking for some ideas.
thank you
Ran my tender leads,direct from battery and zip tied to the frame near the right front wheel. Easy easy.
I did the same thing, you can feed it out the back and to the frame, zip tie it and your good to go.
See What Ann said - comment #4
That's what I do and it works fine!
Note: Depending on the side you choose, best to have the cord at the bottom left or right curve of frunk or upper right or left. Middle doesn't work well :)
AJ
thank you
Dealer had added one on their own but jumpstart had it running between the lip and seal of the frunk. I removed the frunk and drilled a small hole and am going to seal it with a grommet
mark
Our dealer installed a BT wire on our Rt's.but with the alternator on the 1330's,unless the bike is stored for a long time it is not needed like it was on the 998's.
