I'll be ordering these soon, just wondering if removing the Frunk makes this easier on a '13.
Removing the Frunk does make the install easier. You have to weight the added effort and time of the Frunk removal/install against the benefits. If you want to avoid the top shock bolt issue this is a good way to go. The rest of the install is mostly just time and effort. Not high on the difficulty rating.
Be sure to use a little lubricant on the spring compressor tool (WD-40 or similar, chain lube, whatever you have laying around) works well. Just apply it to the threads needed to do the job. This keeps the mess down.
These shock adjusters have been a real sleeper. I have been too busy to market them much and they don't get the recognition that the sway bar does. But, so far, everyone that has installed them is very happy. I just want to reiterate that these are not a substitute for the sway bar upgrade.[/QUOTE
Ok Ron, what about us poor souls with older bikes? What can we do to increase spring tension on the front shocks?
I had the sway bar and then put these on not to difficult to do but they do make a difference very glad I spent the money and did it. I'm 70 and it still wasn't that hard a project.
I am going to install these on my 15RTS. my question is do you gain any ground clearnce after install. One of the issues i see with all the Can ams is the ground clearnce.
COOL You answered all my questions. ill be picking up a set at spyderquest.
