Dealer repaired by finding a broken wire on the DESS module. Should be able to pick up today.
As a warning to you all, you can not get a replacement key programmed to match your bike, if you don't have a working key with you.
If you lose your key while you're out on the road, make sure you have an extra hidden somewhere on the vehicle that you can get to without needing a key, or you will have to buy a new ignition switch and a new DISS module to be able to start the bike and ride, and once again have two keys.
Don't ask how I know this, just know that the cost is over $300. Oh, I'll tell you anyway...
I only had one key, and when it got damaged and lost it's ability to communicate with the DISS, there is no way to program a new key. As unlikely as it seems, you can not get a replacement key if you don't have a working key.
I found this warning in the owner's manual....
"NOTE: Your should receive two keys with your vehicle. Each key contains a computer chip specifically pre-programmed to start your vehicle. Store the spare key in a safe place because you MUST have your spare key to have another one made....."
Don't ever leave home without both keys. One in the ignition and one taped, or tie-strapped to the bike somewhere. Not in the trunk or under the seat. You need a key to get there!
If I were buying a new Spyder now, knowing this, I would have an extra key made so that there were three keys, then I could always have a backup at home in case of a bad situation. Or, if you only have one key, go get another made BEFORE you need it!
Ditto, goes for cars, too.Actually, hubby and I each have a key to the other's vehicle with us at all times. So I always carry a Victory key and he always carries a Spyder key with him. Just in case someone loses a key, locks it into a bag, whatever. My parents got us started to do this. They do it as well. It just makes sense for us. Neurotic? Probably. But it works.
...Also, I see no need to travel with the second key...a little bit of overkill IMHO...just another thing to get lost. I don't travel with two car keys or two house keys either, just the one...
