Is there a map or way to plot a course from one place to another using primarily back roads or less traveled highways ?
If I'm planning a trip I will use Google Maps and use the avoid highways option. Then I will review the route using the satellite view to see what type of areas I would be going through. This can take a while to review but it hasn't let me down yet.
http://www.motorcycleroads.us/
http://www.motorcyclistonline.com/index.html
http://motorcycleroads.com/
hope these will help...I have them marked as favorites
sometimes...most of the time...we kinda know about where we are traveling and just figure it out along the way....
In Oregon, the DMV produces a foldout map (Form 737-3479) that has highlight routes for "scenic motorcycle rides" and "Oregon scenic byways". SWMB and I have found that this is spot on for scenic and interesting routes to take for short get aways.
Best of luck, and like was earlier posted, be mindful of the GPS' information.
hey Cooter/John, how do I get my hands on this fold out map for my OREGON trip ???? ( I am in Canada ) Thanks.
Very cool. They are now bookmarked. Thanks for the info.:2thumbs::2thumbs::2thumbs:
Ride in comfort,
John
Seal FloorBoards
The problem with this, is you are sending only the destination. The Garmin is calculating the route so you may or may not be routed the way you want to go. You must insert waypoints in order to insure it routes you the way you want to go.If you have a garmin GPS. You can go to mapquest.com and make your route then move the lines to where you want . You can then upload this to your garmin. If your garmin is hooked up, click send and you should be able to select your gps.
