Dat Guy
I think I need some help with my audio. I have a 2013 RT SE5 and when I turn the volume all the way up from the normal screen it shows the volume "bar" indicator is being all the way up, but then when I press the mode button and it goes to the auxiliary input screen (which is how I listen to my music through my phone) it shows another volume bar which is only one third of the way up. I can raise this volume bar all the way up, but when I exit and cycle through the screens back to the auxiliary input one it shows the volume as being at one third again. I don't understand what this different volume in the auxiliary screen is used for, or if it even affects the main volume on the main screen. I checked and I do not have the auto volume adjust turned on. Speaking of the auto volume adjust, I'm not sure how it even works. I've tried setting it to low, medium, and high and haven't noticed any affects when speeding up or slowing down. Am I doing something wrong? I suppose in general I have no clue how these things work and looking in the manual did not help, and I found nothing by searching here on the forum. Thanks for any help in advance!
Let me see if I can explain this better with pics.
I turn the volume up all the way to one click from the top, seen here:
Then I press the MODE button and I see this:
So then I raise THAT volume bar up to this:
And then I cycle through each screen using the MODE button back to the AUX screen and it's back to this again:
What's this all about?
