Are there any easy ways to get at the bulb on a 2014 st-s. Tks
Yes, but a little unorthodox and not what the service manual says. I tried that and it was an absolutely futile knuckle skinning/bleeding experience. My wrists still have the scars closing up. So ......
Remove the seat ... 3 bolts and the "V" pin on the hydraulic thing, and unclip the passenger wiring connection. Remove the passenger grab bar. Honest. At least two of the bolts will be v-e-r-y hard to loosen. BRP used a ton of 3M "Loctite" on my 2014 ST Limited. Move the passenger grab bar to the side. You will then be able to see the tail light connector. Give it a 1/4 turn left (remove) replace the light bulb, and put the connector back in place. Button everything back up.
A few weeks ago I installed Admore's LED lights on my Givi saddle bags and of course had to wire everything up. The issue was that BRP left almost no wire for the tail/stop lights to allow connecting to. I removed the side bags, the side bag holders, body side panels, underside (above the rear wheel) panel and still couldn't get at the dumb-dumb Torx screw at the "front" of the tail light housings. Finally in desperation I did what I described (above) and all was hooked up in a matter of minutes.
Go to www.spyderryders.net.au click on "Main" in the drop down menu; click on "Tips and Tricks"; scroll down until you find "Dreading replacing a tail light globe". Good luck...
HiIts a private group. Tried to join a couple weeks ago. My guess is that I am not a Australia resident, they won't let me view their secrets...
The real PIA is getting the screw back into the deep location, I PUT A DROP OF crazy glue on my torx to hold the screw while blindly trying to find the threaded insert. I placed the easy screw in first, the one closest to the rear, and then with the other screw stuck on a extention it made it a lot less frustrating.
I always like to think about the meeting where the engineer explained why they had to make such bad decisions.
Hey Spyderlovers... I went home and made a video for y'alls. (That's how easy it is to do the tail lights now) I've uploaded it to YouTube. Here's the link:
https://youtu.be/xItH12zZOgI
It's about 11 minutes long and covers both the removal and installation. Let me know what you think and if it helps at all.
Nuke
Hey Spyderlovers... I went home and made a video for y'alls. (That's how easy it is to do the tail lights now) I've uploaded it to YouTube. Here's the link::dontknow:
Nuke
Does that include the 60 to 90 minutes to get the backrest, saddlebags, and Tupperware off?
Thx any more info on the bulbs you replaced them with?
thx in advance :2thumbs:
