nightfalcon
I used the Search function to attempt to find definitive improvements from those who have fitted the stiffer sway bar on a Ryker (a Rally in particular, not interested in Spyder results) but couldn't find much. Plenty of 'it's brilliant' or 'transformed the steering' but not much on exactly how it changed compared to previously.
I'm not that unhappy with the stock setup, but I am also curious about this transformational upgrade I'm missing out on. For me it's a $600.00 upgrade which I don't mind paying if there are noticeable improvements, but it would be handy to understand what they might be specifically. I should also point out that I ride my Rally on all surfaces at or slightly above posted speed limits. I wouldn't say I'm a hoon, but I don't hang around either!
So, my questions to those in the know are:
I am hoping for some more specific opinions if possible.
- How did the upgrade improve cornering on sealed road at speed, ie. did it turn in quicker; is it able to get a tighter arc; is there less input on the bars required; less roll; any others?
- Does it noticeably improve handling on rougher sealed roads, ie. is there less flex in the bars; it keeps lines better?
- Did the suspension operate better?
- What improvements were found on gravel roads? Mine has tended to tuck in on the odd corner (slide the front).
- How is it better over corrugations, ruts, and pot holes?
- Does it affect the traction control, ie. give more latitude before it kicks in; makes it kick in quicker?
- Are there any negative affects on the steering; ie. is it twitchy, or a little too responsive?
- Does it improve tire wear?
