Anything special required to change brake pads on these?
Which over the counter brake fluid are people using? Recommendations?
Any name brand DOT 4 fluid should be just fine. I typically use Prestone or Valvoline. All DOT 4 fluids are synthetics, there are some high end brands with higher than spec boiling points, but you will never stress normal DOT 4 on a Spyder. It does still need to be flushed and replaced every couple years due to moisture contamination and the sludge it creates.
