anyone used NMN step lights?
aka1004
i am looking for underbody lights and due to california regulation for underbody light(only red in rear and not visible from front, not even a hint of it) so basically i am gonna need a l.e.d. spot lights.
i need something that projects light in small focused beam in red so i will be more visible from the side but red light is not noticeable from the front
i dont even know if thats possible
seems NMN's step lights have pretty small footstep.
I have used them! :D
That's not the light you would use for this effect.
If you give us a call I can go over where and what to use for this effect. :thumbup:
MM
While you speak with Evan, get all the other LED lights...his products rock...
I was in reverse the other day for the first time and everything was blinking rapidly, including the 'R' on the dash...didn't even know this was supposed to happen...(I hope it is supposed to happen!)...
Evan's triple play, taillight, and fender tipz are awesome!
You are good to go-normal operation fellow Marylander.
We have to get together some time for a ride...I went out on Tuesday for a short while...good enough to keep the bike running smoothly...
I know it's basically winter, but any weekend day I'm not at a seminar...and have a few hours, I'd like to go for a ride out towards Frederick/Mount Airy...and just take to the hills!
Yes this is normal, the 4 way flasher automatically comes on in reverse. :thumbup:
MM
got online to order couple of courtesy lights and shipping were $14 for UPS ground
i assuming they have a flat rate. when i added tripleplay it was still 14bucks
i am still debating over triple play so i guess i will just wait or look for another solution
