Mikey
Well-known member
I am with Peter here, like I said yes you can open the bleeder screw on a brake caliper in most cases if the res is above the bleeder in elevation and gravity bleed the air out. But at the end, I would have someone help me and do a couple cycles of pressure bleed for good measure, for all of the good reasons Peter mention. But I will say if you plain on bleeding your brakes on a regular basis, speed bleeders are a great add on!!
