Has anyone out replaced a water pump module on a 1330 engine?? Got my 2014 RTL out after its long winter sleep. Engine started right up, but within 5 minutes the temp gauge was at half way up. After a couple more minutes, the cooling fans kicked in, temp gauge pegged at the top. Turned off the engine, let it sit for about 10 minutes, started it up again. Same thing. Checked all 3 hoses on the water pump, all 3 not even warm. The service book says if the main supply hose from the radiators to the pump isn't warm, then the thermostat could be the problem.
Let it sit overnight. Tried again today - same problem. I was poking around with the panels off, and it looks to be on the PITA side of things to change out. What say you, members of Spyderlovers?? Would any of you attempt this? Or should I get ahold of the dealer?
