Anyone other than BRP make a 2024 F3S Windshield? If not, why?
jcthorne
Well-known member
Does anyone (other than BRP which has never been released) make a windshield for the '24 and up F3S? I cannot find one anywhere and even the ones BRP lists have never actually been available. If not, WHY?
Actually, I just put a 21inch windshield on my 2021 F3S Special Series. You can order it directly for your dealer.
https://can-am-shop.brp.com/on-road/ca/en/blue-ridge-windshield-can-am-spyder-219400746.html
Not cheap, but easy to install. Took me 15 minutes..
That part number only fits up through 2023. '24 to present are different and the new part number is not yet available. Nor are any aftermarket windshields that I have found. I am beginning to think about buying an F4 Customs shield and fabricating my own brackets or modifying the ones they have for the '23.
Did you try GP Cycleworks (formerly Gustafson) they may have one or make one for you? :unsure:
They make replacement plastic shield for the OEM brackets but do not have brackets. Brackets are only available by purchasing the OEM windshield kit which has never been made available.
Short answer is no, Gufstafson does not have a windshield for the the '24 and up F3S and neither does anyone else.
At this point I am thinking seriously about using an F4Customs for the older F3S and fabricating my own replacement bracket parts as needed. Very surprised that no one sells a windshield for the '24 and up F3S.
Blue Ridge Windshield​
SKU
219401264
This one is specified to fit the 2024 F3-S on the US Site. I went with the Route 129 for my '24 F3. Fits perfectly, looks sporty, although there's not a lot of wind protection. All of these are showing out of stock now. Should be available soon.
SKU
219401264
This has not been available since the 2024's were released, and there's no availability date in sight. It also provides very little wind protection, and does not help with helmet buffeting. I had one on my 2015, and I had to replace it.
When is "available soon" expected to be?
When available - does that mean spares (ie. a mount kit) will be orderable?
My mount bolt, shoulder washer, & moulded cap went AWOL recently.
BRP has never made individual parts of accessories kits available as replacement parts. IE, to get the specific parts you are asking about from BRP will require the purchase of an entire new windshield kit.
Kits that are still not available. Nor are the heated grips kits available!
