How did you hook up the power for the lights?
I fashioned 'Y' shaped brackets and mounted (sandwiched) them under the front plastics. Flip the template over for left side.
I took power from my fuse box (switched 12v) and added a switch in the spare switch slot on the 'tank'. My chin light is on the same circuit.
I don't want to add a switch. Were did you attach the trigger wire?
Just make sure that is legal, ff. Out here in Aus, they will only allow additional driving/spot lights to run off your high beam circuit, and they MUST have a switch, or they will reject the vehicle during roadworthy tests.
No problem here in the USA. You have to see some of the light bars that people mount on their trucks.
No 'trigger wire'. I use a fuse box with 6 12v circuits that can be set for 'key-on' or 'always on'. I connected my switch to a 'key-on' circuit. LEDs can be run as daylight DRLs and/or nighttime added vision.
What is the purpose of the trigger wire?
If you only want 12 volts when the switch is on, then use the GPS wire.
