You're probably right - respect for your experience and knowledge - but I wonder why it stretched so much, bends more than 90 degrees...
There is no tensioner, but maybe an accessory tensioner would be better.
There
IS a belt tensioner, it's the bolts built into the end of each swing-arm - on Spyders, while many do
INCORRECTLY call them '
tensioners', those little roller jobbies that are held by a spring loaded arm and roll on the top of the belt
ARE NOT TENSIONERS - they are vibration dampeners, and while they can help reduce any vibrations felt between about 110 & 130 kph, they can also destroy your belt pretty quickly if they fail!! And they have been known to - often, especially if not maintained &/or replaced regularly! :gaah: There are other ways of reducing belt vibrations, often involving setting the belt tension correctly by using the adjustable slides in the ends of the swing arms that are tightened/loosened by the bolts found back there! :lecturef_smilie:
We can't show you the results page of a search here, so if you want to find out more about setting your belt tension correctly, simply type '
belt tension' into the
Search field up toward the top right of the page; then tick the '
Search Titles Only' box in the drop-down list that'll appear below what you've typed; and
Submit the Search - you can pretty much always disregard anything that has a title with the word 'tensioner' in it, cos they are usually (& erroneously! :cus: ) referring to those belt roller DAMPENERS, not the
real tensioners; and spend some time reading thru the other threads that are discussing how to
set your belt tension and alignment properly - it can be a fiddly and frustrating experience to get it all exactly right, but if you can get down there to do it and you know which end of a screwdriver to hit & which end of a spanner to spin, then you should be able to do it yourself! :thumbup: - I really doubt your belt has stretched sooo much that it now can't be tensioned properly!!
That said, if anyone has ever had the rear wheel off, and didn't know those tensioners were in the ends of the swing arms, they are loose & can fall out, so there is a possibility of that, but you should be able to see the holes where the missing parts should go; and I have seen a couple of Spyders where whoever assembled/re-assembled them managed to miss looking at the belt tensioners entirely & either left them very loose or didn't tighten the axle tube properly at all, but usually, that sorta thing means the Spyder either doesn't go at all, or the belt slips
A LOT and sounds like a machine gun when it does slip whenever you try to accelerate. :shocked: Mind you, that slip & noise is also a sign of worn teeth on the belt &/or sprockets too; but like I said earlier, that sort of wear doesn't usually happen without
a WHOLE LOT of miles being done to cause it! nojoke
Still, it sounds very much to me like you need to do some reading, maybe watch a vid or two, and then get down to adjusting your belt tension - Good Luck! :cheers:
