Yup! :thumbup: I've done two of them now...
Getting that bugger unfolded, and then stuffed down into the trunk takes some patience...
I normally mount up the velcro on the front inner panel first, and secure the liner there...
You kind of get an impression from the liner, that it's molded to fit around all of the nooks, crannies, and bulges in the trunk; use those for your guides! :2thumbs:
If you work your way around to the sides next; you'll kind of get the idea how the panels overlap each other... patience, and a second set of eyeballs never hurt!
Good luck! :thumbup:
Oh! Do you have a Limited with the shelf? You'll need to remove the shelf from the bike, and then make a slit in the line where it meets up with that flat and angled part of the panel, then; re-install the shelf through it!
