Anyone do SE5 Clutch replacement I have 2013 RT-S
taxmyzer
I would like to how difficult it was to replace to install a new clutch kit for SE5. Also how many miles on the bike before needing to replace the clutch. Thanks
First, I would ask why you feel the need to replace the clutch? Treated right, the clutch on a Spyder should last a very long time. More miles than most will ever put on their Spyder. Using the wrong oil, or running your SE5 at too low an RPM can send your clutch to an early grave. But other than these things, your clutch should be pretty much bullet proof.
The SE5 has 2 clutches - the centrifugal one referred to above and the normal (SM5) clutch. I've had the clutch pack out of my SM5 to replace an oil seal on the water pump shaft. Which one are you specifically asking about?
