Anyone change the tires on their RT
westgl
Orbital Blue RT-SE5
Has anyone put new tires on their RT,
What tire, and what was the difference.
I keep hearing that changing the tires makes a big difference in handling.
I hear that the Sumitomo has a good tire, that is good against hydroplaning, that fit the Spyder.
Rear Tire
I replaced my wifes rear tire at 6500 mi. , center was gone, I put on a Nitto NT450 Extreme Performance tire , I believe was $90 from onlinetires.com in correct size now at 3000mi. cant tell any wear tire is rated at 45000mi. I believe, running at 18psi. Our previous trikes ran at 16-18psi. the recommended 28 psi. wore center out way early, seems like very good tire in rain she hasnt slipped the first time.Mounted at home manually checked balance , tire had familiar yellow balance dot she has been in triple digits smooth as silk.
