SPYD3R
OK all you F3 aficionados out there... have any of you replaced your own BOUGIES, (French for SPARK PLUGS)...? and if so, would you please provide any tips, suggestions, videos, etc to help a fellow F3 rider.... what i can see, is the need to pull the entire top off the F3 to access the plugs... hopefully somebody has found a way to get around this... if so, please advise the rest of us as to just how we go about it... i found 1 video on UTUBE:
and this guy has his beast down to the bones... he even states that it's a big job.... hope this isn't an ABSOLUTE NECESSITY to changed 3 plugs...
i'll be preparing my F3 for the ride out to the Deadwood, SD event in July, and i believe on getting an early start on the maintenance... already have the oil & gas/filters, brake pads & plugs... already did the brake fluid flush and anti-freeze... will check tires the day prior to leaving, since PSI can change without notice...
HELP...!
Dan P
SPYD3R
HELP...!
Dan P
SPYD3R
