Any suggestions on how to fix this recurring EDB Fault?
ricrdo2
We just obtained a new to us 2010 Can Am Spyder RT SE5. It had sat in a garage on a tender and started at least every two weeks with some short rides up a gravel road. When we received it, the brakes were essentially non-existent and the fluid was almost amber looking.
After hauling it home, during the unloading process the mashing of the brake caused the “brake failure” code to appear. Front, rear, and VCM were flushed with new fluid. After this service, the brake failure fault was reset using the limit switch reset without using BUDS.
An oil change was performed and new gas was added. A 90 mile shake down ride was performed and about 70 miles in, the engine just stalled. Speed was about 50 mph and temp gauge was in the middle. The engine wouldn’t start. After sitting a few minutes, it finally cranked, but it seemed to be hunting to find Neutral. The bike made it home another 20 miles, then once at home after shutting it off, I attempted to restart it. It would just crank but it wouldn’t start. After the 4th attempt it did start, although an error code appeared then disappeared - "EBD Fault". After some research, I decided to buy a new battery.
After replacing the battery last week, we went for another ride. 15 miles up the road, we parked and shut the engine off. Upon trying to restart, it wouldn’t start up. After a while, it started and the EBD message appeared again. What we noticed is that IF we shut it off and ensure it is in Neutral it fires right up and has no issues; but if we turn it off in gear, it will not start up immediately, and when it does, it provides that fault.
Other things of note, we rode deliberately ensuring we weren’t riding the brake pedal, as we have seen some posts saying that this can be a cause.
Any advice would be greatly appreciated. Being an older model, I was trying to avoid an expensive trip to a dealership. Thank you for any help!
You may want to make sure that the fluid is up where it supposed to be, sometimes just a dab will help, make sure your floats are not sticky. On your wheels make sure that your sensors on the tone rings are clean and the air gap is set to spec. When you did your brake job did you take the sensors off, you didn't drop any spacers did you? The starting thing has me a little puzzled, why trying to start it with the brake pedal pushed, it cranks but will not start :unsure:, I make it a habit to always have my bike in neutral before I shut it off, and when I don't as long as I have the brake pressed hard it just starts and puts it's itself in neutral! I'll have to do some poking around on that one, Good luck!
Try getting the exact EBD default that the bike is throwing and use Claude AI to search for it on the Internet. You may find something that way or you may just have to take it to the dealer to debug.
