Any hints on re-assembling the headlight adjustment gears?
I am new to this forum and not sure how it works. I accidently pulled apart the 2 gears inside the headlight assembly that turn to adjust the headlight position. I have not been able to put them back together. Is there a trick or a special tool needed to reconnect the assembly? It is a 2016 Spyder F3 Limited Edition.
Just guessing the gears are probably part of outside the housing adjustments usually with a Philips head screw. Look at owner’s manual for location ,hopefully helpful.
Go to ....canamoemparts.com .... and look at the Fiche' that shows this part .... you will see how it goes together .... Mike :thumbup:
My F3 has 2 of each for the headlights.
I guess the OP could have a look at the other one and see how it fits together. :dontknow:
