Spyder_Cowgirl
GOS member (Girls On Spyders)
Has anybody installed a CB on the F3? Not really interested in a hand held that is simply "used" ... I am looking for a mounted unit with a good antenna and, likely, blue tooth to route to the helmet.
If on a 2018: Were you able to use the built in blue tooth to "integrate" the CB communication with the Spyder. I know J & M makes a blue tooth interface module that allows pairing the CB as a headset (this is what was done on my husband's Indian).
If on a 2017: Did you / Can you add a blue tooth dongle and then "integrate" the CB communication with the Spyder (as above, also using a blue tooth interface to the CB and dongle).
I am at a crossroads .. have some mighty good offers from BRP and am toying with getting an F3 Limited. But, a CB is simply a requirement for communication with hubby and also the group we normally ride with. So ... looking for anyone with real experience in CB implementation on the F3.
Many thanks .... Ann
