I don’t think I am going to have any issues with getting the bar out as I have a 14“ deep drainage well in my garage and will lift the bike over that so the bar will drop out easily enough without having to add any cribbing to my motorcycle lift.
However looking at the bolt #9 and nut #6 that holds the sway bar in the channel frame it appears to me that I can’t get wrenches into that area without removing the splash guard? I have not yet lifted the bike to look from underneath when lifted but laying on the floor with a good light underneath the bike it does not seem there is any opening underneath the channel frame member. Is there a trick to this? I put a baja ron sway bar on my STS and it was relatively easy to get to the bolts holding the sway bar in but on the F3T it looks like it will be difficult to get wrenches into there to remove and replace the bolts?
