NancysToy
Motorbike Professor
As usual, we have a great many differing opinions here. All actually have some merit. For some people, their riding style and the climate can make the Spyder (or another vehicle) run worse when the engine heats, or at higher ambient temperatures. The engine management system can compensate for the tendency to knock under these conditions, but performance can be degraded to the point where it is horribly noticeable. My wife's HHR is a case in point. Never knocks on regular, but has no zip and runs poorly sometimes. Has plenty of go at all times on premium, and actually gets far better mileage.
One of the confusing factors is that everyone rides differently, and lives in a different area. That means that not only is the climate different, but the fuel supplies vary both regionally and seasonally. What is good for one rider may not work for another. To complicate matters, the Spyder has a relatively limited ability to compensate for higher or lower octane. While it may not knock as octane drops and temperatures rise, it may reach a point where it runs out of ability to compensate and acts up horribly. On the other side of the coin, it has little built in compensation to allow more ignition advance if the engine doesn't knock, so increased performance is less than what it might be. It is not capable of pushing your eyeballs to the back of your helmet just because you ran high octane fuel. As a result, we are all quite confused.
Run whatever kind of fuel seems to make both you and the Spyder happy. If you put 15,000 miles on your Spyder in a year, the difference between regular and premium fuel costs will only be $200. That won't buy many mods...and it won't put you in the poorhouse, either. You are the only one you need to please. No sense in trying to convince everyone else.
