I know, I know...It's only a $30 item. But, I was kind of worried about getting the tip of my riding boot stuck under the extended brake pedal. Any feedback from those who have used it?
Hank
Sent a pm.I know, I know...It's only a $30 item. But, I was kind of worried about getting the tip of my riding boot stuck under the extended brake pedal. Any feedback from those who have used it?
Hank
I have installed one on our RTL and even though I feel a little cramped on it, I have yet to hook my right boot on or under it. It has helped quite a bit and I don't have to hunt for it like I had to with the smaller pad. Mad MacI know, I know...It's only a $30 item. But, I was kind of worried about getting the tip of my riding boot stuck under the extended brake pedal. Any feedback from those who have used it?
Hank
I have tried both the Refined Cycle extended (BPE2) and the full size brake pedal and have gone back to the stock one.
The larger brake pedal extends across the floor board and takes up foot room for me. I find I am always bumping into it and have to ride with my foot behind it. And I was afraid if I had to smash the brake the floor board would stop me from doing so.
The extended pedal, BPE2, allows you to use your rubber pad. I had a couple of problems with this. The pedal is very close to the tupper ware so you can only get your toe on the pedal. I have the NBV highway pegs and with my feet on the pegs my heel would touch the pedal and turn off the cruise.
I also tried the combination of using the extended pedal with the larger rubber pad. This looks really good but was too heavy. I would have to put on a stiffer spring to hold the pedal up.
Others are probably using one or the other and works for them but this is what I found. Hope this helps.
I installed something very similar but I mounted it in a way that it lowered the extension so I didn't have to pick my foot up so much to press the pedal. I like this because I can use the toe of my shoe to press the brake vs. I had to pick up my foot or role my ankle to use the standard pedal. With the standard pedal my foot got very tired from a day's ride.
Rob
Have you tested that setup to make sure that the pedal does not hit the floor board before it can trigger the floorboard release. If the floorboard does not drop down. You will not have full braking performance in an emergency.
