And so it begins...
crhannig
The wife has been spending her Christmas money on Spyder parts and accessories, one of the first parts to arrive was the Can-Am Auxiliary light which goes on the front spoiler.
Pretty easy install.
1. Undo 2 Torx screws
2. remove the honeycomb panel
3. Unplug the cable from the panel
4. Connect Cable to light
5. Use the 4 Phillip head screws to fasten light in place.
This light comes on when the Spyder is on and the engine is on just like the headlight.
The light doesn't put out a ton of light in your path, but it does illuminate around the front of the Spyder which helps with traffic seeing you and also when riding in unfamiliar areas. You can see if there are dips and curbs easier.
You must be new. A very warm welcome to the group.
You're about to enter a new dimension of modifying your Spyder.
attachment.php
Everybody is tossing around the word "farkle" like they know what it means.
Do you know that it's actually an acronym? (I do.)
Can anyone else fill in the blanks?
F ___________
A ___________
R ___________
K ___________
L ___________
E ___________
F ___________ Fancy
A ___________ Accessory
R ___________ Really
K ___________ Kool
L ___________ Likely
E ___________ Expensive
Added answer above.....................:coffee:
I put the Auxiliary LED light and the Signature lights on my RT, more for visibility ...others seeing me. I find the factory lights work really well
