IdahoMtnSpyder
Well-known member
One year after JC's install
I'm just now working on doing this same install. I've run into the same problem Tweakers did. There is no question the inline box is now a bit larger than when JC did his install a year ago. There is no way to fit the box in like JC did and not jam the shutter. I believe I will do the same mod Tweakers did, remove tabs on one side of the PC board holder. I may add a pic or two to add some additional info to what Tweakers has above.Finally got the LED headlights installed. I ended up removing the circuit board, had to trim off tabs on the sides of the circuit board holder which then let it move enough sideways to disengage the bottom of the holder and remove it from the housing. This allowed me to insert the LED Box in one side and run the lead to the light under and then up the other side of the shutter solenoid. I could then fit the circuit board holder back in the general area it came from with the bottom section removed, reinstalled the circuit board and fiddled with its plugs until I had them where they didn't interfere with anything. The plug from the LED box I set by the light socket and tucked the black lead down between the side of the housing and the socket. All the while I was checking the shutter for unobstructed motion and keeping wiring as far away from the solenoid as possible. I then bent the heat sinks down and around the bulb housing, trapping the power plug under them. Shout out to JC for the photos to give me the determination to wrestle with this project. I almost gave up and installed them in my Motorhome. Lol
