ALWAYS USE HIGH BEAMS DURING THE DAY!
I heard the other reason for running the brights most of the time is that many RTs have a problem with the headlight shutter bouncing on rough roads and giving the impression the headlights are flashing... with the brights on, the shutter is fully retracted. I have seen this in practice when an RT was behind me on the road and running the brights ended the problem.
I wonder how many others have seen the bouncing shutter problem and can it be fixed ?
:agree:
It is not the shutter that bounces, it is the Spyder. That can make the edge of the beam which is cut off by the shutter bounce in and out of the viewers's line of sight. The fix is to run high beams in the daytime, to project a wider beam that remains in sight continuously, and to aim the headlights properly. On low beams the cutoff should not shine high enough to shine into the eyes of oncoming traffic. The beams are supposed to illuminate the roadway, not spotlight other drivers. The effect of the projector beams and the cutoff from the shutters takes some getting used to. Because the low beams don't illuminate everything in sight, some owners think they aren't working well. In truth, they light the road better than most motorcycles, just not the surrounding area.
This was one of the things covered in the NCDMV motorcycle study guide. Always run highbeams during the day.
I don't think that meant topless, even though some may have interpreted it that way....:joke:
I have HID lights in my F-150 and they work the same way as the Spyder. If you have HID's in your vehicle this should be nothing new as far as the shutter and seeing the cutoff point on dim when driving at night.
Because the Spyder comes with the shutter system instead of double filament bulbs, it makes it ideal to change them over to HID. I did, and what a difference it makes.
I think I'll stir the pot a bit. What do you say to the Law Man that stops you for having your high beams on?
Chris
I'm confused. According to some posts, if a following ryder doesn't have their high beams on....the ryder essentially disapears? You can't see the Spyder, ryder or even an outline of them???
I have lead a ride with 10-12 ryders and a couple of them had their high beams on, one of them right behind me...with his highs on, I was unable to see around him to see the rest of the group. But on other parts of the same ryde, I could look over my shoulder on a long sweeper and had no problem either counting Spyders nor seeing my tail gunner.
Personally, I only run my highs at night with no oncoming or following traffic. I have never had an instance where my high beams would have made a difference.
You got it right. Although I think you meant to say "no savings in bulbs or power by using the low beams".
The Spyder bulbs are not double filament bulbs. All the watts all the time.
You are correct except the Spyder ST has double filament bulbs.
It is not the shutter that bounces, it is the Spyder. That can make the edge of the beam which is cut off by the shutter bounce in and out od the viewers's line of sight. The fix is to run high beams in the daytime, to project a wider beam that remains in sight continuously, and to aim the headlights properly. On low beams the cutoff should not shine high enough to shine into the eyes of oncoming traffic. The bea,s are supposed to illuminate the roadway, not potlight other drivers. The effect of the projector beams and the cutoff from the shutters takes some getting used to. Because the low beams don't illuminate everything in sight, some owners think they aren't working well. In truth, they light the road better than most motorcycles, just not the surrounding area.
:agree: Good explanation.
I always leave my High beams on day and night and I've never had any oncoming vehicles flash their brights at me.
Wow! You're right......................I can't see my headlights very well :yikes: .......................oh, that's right; I'm sitting behind them. :hun: :joke:
I'd just tighten up the dumb look on my face (I'm REAL good at that! ):shocked:, and say, "They ARE?? I'm sorry sir!", and I'd flip them down...
Then I'd thank him for keeping a good eye on all of us! nojoke
After all; he's not going to be in front of me forever! ;)
I also put HID's in my RT. I have been ryding with those on low because if I do so with high beams, I get all kinds of complaints about it being too bright. The HID's are a vast improvement over the stock bulbs. How may out there with HID's are running at high beams during daylight hours?
