I have an opportunity to buy either an Aluma UT10 trailer or an OHT3 trailer. I have a Spyder and 2-wheeler. Which one would you get?
TX, Bob
UT10 -
OHT3 -
After watching numerous videos and reading a lot of reviews, I opted for the OHT3. I bought new, in Jan of this year & towed it home from (near) Denver in miserable weather, with a Hybrid vehicle. My wife & I took turns driving and didn't even know it was behind us; the OHT is light, aerodynamic, well balanced, tracks perfectly, and is dead silent; but I wouldn't tow it loaded behind a small hybrid vehicle!
I recently drove to Minneapolis with a friend, picked up his new 2023 RTL and drove home (some 250 miles) with the same results... and got 15+ mpg @ interstate speeds with my F150 3.5 Ecoboost.
With 1,000 miles on it, and only 1/4 of them loaded, here are the upsides and downsides:
UP's:
As mentioned above, the OHT is light, aerodynamic, well balanced, tracks perfectly, minimal bouncing, and is dead silent.
It comes with a jack and castor wheel, making it very easy for one person to roll it around and attach; the jack folds and locks against the spare tire.
No ramps! There is an air dump valve on the right fender that deflates the airbags and drops the rear to the pavement and the entire deck becomes your ramp. No worries about clearance!
Once you are on, you use a remote on your new key fob to "air up" the suspension.
Comes with AL wheels, good tires & locking lug nuts.
Has optional brake axle, if you want. (extra $)
Offers a Spyder specific tie down kit. (extra $)
DOWN's:
It is pretty wide, wider than my F150, so you have to be very watchful on corners.
Can't see the tail end of the trailer when towing and you can't tell where it is when backing up.
Lighting is minimal; what little clearance lighting there is won't tell you where the fenders are in regards to the lanes at night.
The onboard air system is adequate, but the air tank is a sealed frame crossmember and doesn't seem to have enough capacity to raise the bed in "one shot"; it takes 3 cycles for the compressor to raise the bed when fully loaded with my RTL (just takes a little longer than I had hoped!)
When the deck is aired down, there is still about a 1 1/2 to 2 inch "jump" to get on; still, it's not a bad deal, it just could have been designed a little better.
If you have a flat, I think it's going to be more difficult to raise as the air suspension needs to be locked to lift the tire. (fingers crossed)
Overall, I really like the trailer. I hope to update this after I have pulled it (loaded) for a while. I hope this helps in your decision-making.
